Topic: Video not going to second scree
Hi Guys, help please
I use the video feature a lot and have done so for many years. Last night the video would not show on the extended screen and popped up as full screen on my my screen. I've had a good look through the settings but can't find anything to fix this. I haven't changed any settings for this to happen but have had the usual VDJ and windows updates.
TIA
geposted Sat 12 Aug 17 @ 9:14 am
If you're using a laptop, have you got a integrated/dedicated graphics card setup?
Sometimes issues can occur if you don't have both active.
Also, if you select the video mixer panel, right click on the master output, there should be a list of available screens to choose from. If there is only one showing there, then it will most likely be an issue with your windows/graphics set up
Are you computer detecting or identify your second screen?
