I have just downloaded virtual DJ 8 and when I load a song, the rhythm viewer is one solid colour. I can't see the waves anywhere. How do I fix this problem?
geposted Mon 14 Aug 17 @ 11:58 pm
Try with the VirtualDJ 8 "Default" skin. Most likely you are using a version 7 (or earlier) skin on Mac.
geposted Tue 15 Aug 17 @ 12:53 am
Are Atomix ever going to fix this issue (old rhythm code not working on Mac)?
@mattymac - it can be fixed, but the skin needs modifying. Which skin is it?
geposted Tue 15 Aug 17 @ 4:29 pm
