Topic: Adding new command to mapper
Hi all. Setting up a new controller based on the original mapper. But I can't for the life of me work out how to add a new button or led. If you select a existing command, it stays in the windows... There's no button to create a new command for say a led. From memory you can press an unmapped button somehow to map it.
It's been a few years since I've mapped, and I know even less about V8
Thanks
geposted Wed 16 Aug 17 @ 10:54 am
To add a new Key in the mapping, you need to select it from the Key list (right above the Action box)
