Topic: Beat juggle only one direction.
Hello. I currently have beat juggle applied to one of my controller buttons. It works well but not liking that if pushed more than once it will switch direction from forward to backwards or vice versa. Is there a way that when the button is pushed that it only beat juggles say half beat forward? If the button is pressed again it won't try and switch to a half beat behind ? Thank you, any help would be appreciated. I'm using numark mixtrack 3 and VDJ LE.
geposted Thu 17 Aug 17 @ 8:40 pm
Try this script
goto +0.5
Worked perfect! After seeing some of your other scripts it's like asking a mathematician what number comes after 1. Thank you for taking the time, much appreciated.
