Hi everyone,
I'm a very new beginner to VirtualDJ. Today I was using the "Track Cleaner" function on a bunch of songs that I have on my Macbook HD and using the automix feature. Afterwards, I accidentally hit 'export' and moved the remixed tracks to a folder outside of VirtualDJ. I have put back the playlist within VirtualDJ but all the songs that I edited now show up as "ERROR". Is there any way to fix this or will I have to do this process over again?
Please help!
Please help!
geposted Fri 18 Aug 17 @ 6:09 pm
right click file hit relocate and tell it where the file is
geposted Fri 18 Aug 17 @ 7:17 pm
@wicked thanks for responding. When i right click, I don't see a 're-locate' button. Please see below for what I can view:
http://imgur.com/a/76iFd
Would you mind letting me know next steps?
Thank you very much
Thank you very much
geposted Fri 18 Aug 17 @ 7:36 pm
only files with a red X are the ones VDJ can't locate that file seems fine from what i see ....
if VDJ can't find the file relocate is at the top of that menu.
geposted Fri 18 Aug 17 @ 7:47 pm
I've been trying to find where re-locate is; don't know why I'm having a problem.
Would you mind taking a look at the link below:
When I click on the song (the .vdjedit file), it shows up as ERROR (as seen) and I can't seem to find the 'relocate'
geposted Fri 18 Aug 17 @ 7:54 pm
i look at the image ... there is no relocate on that menu because VDJ thinks it knows where the files is.
post a shot of the error message please
geposted Fri 18 Aug 17 @ 8:00 pm
sorry I linked the wrong image. Here it is:
http://imgur.com/a/sp79D
geposted Fri 18 Aug 17 @ 8:16 pm
ok so VDJ knows where the edit file is but did you move the original file that is what seems to be missing.
VDJ requires the original file to stay put as well and the vdj edit files
you may have to re-create the edit and not move the files after
geposted Fri 18 Aug 17 @ 8:21 pm
