Hello, I need some help I have a Vestax Pad One,to trigger hot cues, samples,Loops and FXs when using the Pads for Echo FX I mapped 4 buttons for Echo On + Echo slider 1/4 beat , 1/2 , 3/4, 1beat used this script:
the issue is when I'm pressing one pad I have to let go and press next to have the Echo effect On, if I press both pads the effect will deactivate....
what script code should I use?
the Loop pads/loop roll (1/8 ,1/4, 1/2, 1 ... ) pads work fine,like VDJ "listens" to the last pad pressed.
thank you
deck left effect "echo" active while_pressed & effect_slider "echo" 2 40% , 50% , 60% , 70%
thank you
geposted Mon 21 Aug 17 @ 11:52 pm
deck left effect_active 'echo' on while_pressed & effect_slider "echo" 2 40%
Try like this.
Try like this.
geposted Wed 23 Aug 17 @ 4:34 pm
I want locodogs brain, that man be a script genius
geposted Wed 23 Aug 17 @ 4:44 pm
Try like this.
Try like this.
this way when I'm pressing 1/8 beat pad, then press 1/4 beat pad the Echo will stay On but if I release the 1/8 beat pad the Echo will de-activate. not has expected, but its getting close.
geposted Wed 23 Aug 17 @ 4:58 pm
When you get frantic with the button bashing, I've found that vdj misses the midi note off signal.
@staff could you explain stuck commands?
You can script round this weirdness by first inverting the desired command,
I'll get back to you once sober.
geposted Wed 23 Aug 17 @ 6:56 pm
deck left effect_active 'echo' off & effect_active 'echo' on while_pressed & effect_slider "echo" 2 40%
Try like this, mk2
Try like this, mk2
geposted Thu 24 Aug 17 @ 2:56 pm
thank you, but same result. when releasing the previous pad echo will de-activate...
geposted Thu 24 Aug 17 @ 7:01 pm
I'm not sure what you are after then.
Please explain what you want to happen, step by step.
I press this, and I want this to happen, I stop pressing that and I want this to happen.
geposted Sat 26 Aug 17 @ 8:55 pm
I wanted to "play" the Echo pads like playing the piano. I mean I wanted to push from the last pad: Echo ON + slider 1beat ; then pad echo slider 3/4 ; 1/2; 1/8 , and to do this I must push one pad at a time,let go and push next, I wanted to slide my finger trough the pads. the loop roll pads or slicer pads work this way, I can push all pads and vdj will listen only the last pad pushed.
thank you
thank you
geposted Sun 27 Aug 17 @ 3:00 pm
In order to achieve the same behavior as the Loop Roll actions, each button needs to trigger its own variable and you need to query each one of those when a button is "up"
Here is a working example with 4 buttons triggering variables test1 to test4 and each one is querying the status of the other 3 variables on up (code in red is the up status)
(replace the test1 to test4 names with something more "unique")
Button 1
set 'test1' 1 while_pressed & down ? effect_active 'echo' on & effect_slider 'echo' 2 20% : var 'test2' 1 ? effect_slider 'echo' 2 30% : var 'test3' 1 ? effect_slider 'echo' 2 40% : var 'test4' 1 ? effect_slider 'echo' 2 50% : effect_active 'echo' off
Button 2
set 'test2' 1 while_pressed & down ? effect_active 'echo' on & effect_slider 'echo' 2 30% : var 'test1' 1 ? effect_slider 'echo' 2 20% : var 'test3' 1 ? effect_slider 'echo' 2 40% : var 'test4' 1 ? effect_slider 'echo' 2 50% : effect_active 'echo' off
Button 3
set 'test3' 1 while_pressed & down ? effect_active 'echo' on & effect_slider 'echo' 2 40% : var 'test1' 1 ? effect_slider 'echo' 2 20% : var 'test2' 1 ? effect_slider 'echo' 2 30% : var 'test4' 1 ? effect_slider 'echo' 2 50% : effect_active 'echo' off
Button 4
set 'test4' 1 while_pressed & down ? effect_active 'echo' on & effect_slider 'echo' 2 50% : var 'test1' 1 ? effect_slider 'echo' 2 20% : var 'test2' 1 ? effect_slider 'echo' 2 30% : var 'test3' 1 ? effect_slider 'echo' 2 40% : effect_active 'echo' off
PS. If for some reason you need to define the deck, you need to add the deck x in front of every action/verb, so Button 1 will become...
deck left set 'test1' 1 while_pressed & down ? deck left effect_active 'echo' on & deck left effect_slider 'echo' 2 20% : deck left var 'test2' 1 ? deck left effect_slider 'echo' 2 30% : deck left var 'test3' 1 ? deck left effect_slider 'echo' 2 40% : deck left var 'test4' 1 ? deck left effect_slider 'echo' 2 50% : deck left effect_active 'echo' off
Button 1
Button 2
Button 3
Button 4
geposted Sun 27 Aug 17 @ 9:44 pm
thats it!
thanks a lot djdad & locodog
geposted Mon 28 Aug 17 @ 9:06 pm
Please little help :
I config pads on my ddj-1000 . How make script : padfx 'ECHO' 0.4 0.5 0 0.1 ???? ( Source Mute ON ) (Trilling Stop OFF) smart_pressed
geposted Wed 06 Nov 19 @ 10:01 pm
