Volume sliders on controller are working only with some sampler banks...
Actually, only with one bank of samples they work but only first 4 sliders, other 4 doesn\t work... and all the others banks not even one slider is working...
I have checked mapping and there is this line for each of 8 sliders : slider 1 has line "sampler_group_volume 1" , and same for all other, slider 2 - sampler_group_volume 2 etc and slider 9 - "sampler_volume_master" line.... but they are not working, volume stays same when i slide it up or down...
enyone knows what seems to be the problem ?
geposted Tue 22 Aug 17 @ 4:52 pm
btw. master slider works fine on every sampler bank...
geposted Tue 22 Aug 17 @ 4:55 pm
If the samples are not in groups then the sliders do nothing only the far right master works without grouped samples.
geposted Tue 22 Aug 17 @ 4:57 pm
And on default banks only instruments has groups defined
geposted Tue 22 Aug 17 @ 5:08 pm
Thanks guys, I will look it upo more to find out about sample grouping
geposted Tue 22 Aug 17 @ 6:03 pm
maybe this can help you out https://www.virtualdj.com/manuals/virtualdj8/features/sampler.html
geposted Tue 22 Aug 17 @ 7:14 pm
