Virtual DJ 8 is not reading my ContentGroup tags that exist before the file sees VDJ8
I have many files with this tag that do not get imported.
if I add a Grouping tag inside VDJ8 they work fine. the problem I have is with files that have it before adding to the database.
I am using all 320kbps Mp3 files and they use ID3v2.3
this is making it hard to sort my files.
Thanks
Thanks
geposted Wed 23 Aug 17 @ 10:38 pm
Which tagger do you use? I tag my files with Tag & Rename and Grouping field gets read by VirtualDj properly...
geposted Wed 23 Aug 17 @ 11:43 pm
foobar2000 and sometimes mp3tag neither of which gets read.
let me try with tag and rename
geposted Thu 24 Aug 17 @ 1:09 am
i seem to have it working with tag and rename not sure whats happening with the other software.
thanks for checking
thanks for checking
geposted Thu 24 Aug 17 @ 1:18 am
