Topic: Mic input too low
Hi all,
Curious if anyone else has had this problem.
I have a NS7-III that I use with Virtual DJ. I have a Shure mic plugged into the microphone port on the back of the unit that I have selected on Channel 1 of the NS7's mixer, set to "MIC" on the switch for the channel.
However I think VDJ is telling the NS7 that the mic is at line level because it comes in about 50dB too low. I have tried to compensate by cranking the EQ's all the way to max, but it still comes in very low.
The same microphone works fine if I simply close VDJ and open Serato with no hardware changes whatsoever, so this is certainly a VDJ-specific problem.
Does anyone know of a fix for this?
Thanks!
geposted Fri 25 Aug 17 @ 8:38 pm
