Hi all,
I have recently upgraded to 8 and noticed that the loop functionality works slightly different. When I start a loop with the IN the song keeps rolling on the back so that when I hit the OUT button it jumps to the current playing position as it never looped. I can see the coolness of this on certain situations but other times it breaks the mix. Is there a way to disable this functionality?
I would like to exit the loop on the current playing position as it continued playing rather than jumping forward on the song to where it would be if I never looped.
Thank you.
Thank you.
geposted Sun 27 Aug 17 @ 9:03 pm
You need to disable the Loop Back mode
http://www.virtualdj.com/manuals/virtualdj8/interface/decks/decksadvanced/loops.html
geposted Sun 27 Aug 17 @ 9:08 pm
Slip mode, surely?
Ah it's called Loop Roll in VDJ.
geposted Sun 27 Aug 17 @ 9:30 pm
Hi,
Thank you for your response. I see that the LOOPBACK option has 3 options, ON, OFF and SMART. All of them behave the same way. I also created a custom BUTTON with the loop_back and in both cases (on/off) still jumps to the forward song position. Any ideas of what I am doing wrong?
Thanks
Thanks
geposted Sun 27 Aug 17 @ 9:31 pm
Yes! That was it, slip mode.. So simple I now feel slow... hahaha
It was driving me nuts!
THANK YOU..
THANK YOU..
geposted Sun 27 Aug 17 @ 9:36 pm
Turning it on/off is in the manual...
https://www.virtualdj.com/manuals/virtualdj8/interface/decks/decksadvanced/loops/index.html
geposted Sun 27 Aug 17 @ 9:38 pm
Thank you. Reading now!
geposted Sun 27 Aug 17 @ 9:42 pm
Solved! Thanks a lot!
geposted Sun 27 Aug 17 @ 9:49 pm
