Topic: knob (jogwheel) sensitivity and range command ?
Hi.
I want to set my knob that when i turn it (touch it a bit) it sets my selected effect of that knob to zero (all the way to left)v and when i turn it to right it goes all the way to right... and i want to control the sensitivity of a know in script.. any sugestions?
many thanks!
geposted Mon 28 Aug 17 @ 11:06 am
I can't understand what you want to exactly, but my guess is this:
param_smaller 0 ? effect_slider 1 +0.01 : effect_slider 1 -0.01
The parts in bold are the ones that affect sensitivity...
Hi, PhantomDeejay! thanks
I tried that line, but its not quite good... It sets sensitivity as i wanted, that is cool and thanks! But I want also to set "range" of a knob!
like, in whatever position my knob is (on controller) , when i try to twist it on right or left, i want that on my effect knob in vdj, it resets to zero, so when i again twist knob to the left all the way, that it goes all the way to left in vdj too... just to set it move normally, from 0 to 100% same in vdj like on controller....im not sure how to explain better, i really hope you understand what i want...
So, to get this right ?
You want the effect slider to return to zero when you turn the knob to the left, and keep rising normally when you turn it to the right ?
param_smaller 0 ? effect_slider 1 0% : effect_slider 1 +0.01
If you want the effect slider to return to zero when you "touch" it and then operate as usual, that's not possible for a knob that doesn't send a separate command when you physically touch it.
"You want the effect slider to return to zero when you turn the knob to the left, and keep rising normally when you turn it to the right ?"
I just want it to act normal, like those knobs on controller that are already set, that has mappings inside vdj already. i tried your script and it makes knob go strange, like it goes to left and i move it to right, than it goes to right but not all the way to the right, and i moved it on controller all the way and than it wont go neither left or right...
sorry, with this srcipt "param_smaller 0 ? effect_slider 1 0% : effect_slider 1 +0.01"
i just noticed that its using only half of the knob as whole knob (full circle)
im moving knob all the way to right and it moves knob in vdj from zero to half of the knob, and i move it than to left to the half and it continues moving knob to left (other half) , but as soon as i cross the half to the right it resets to left to 0... arghh :)
can i send you a video somehow here? its difficult for me to explain in english
but basically with that script you gave me it only uses half of the knob on controller, when i cross 50% of knob circle it resets knob in vdj to left to 0%. if i continue move knob on controller to right nothing happens, it stays on left and on 0%. if i go back and go 49%, 47%, 46%.....to 0% to left it starts rising up till 50%.
now I am at the 0% to left on controller knob, and knob on controller is at 50%, i then move knob controller to right and knob in vdj continue rise until 100%.
again i come to 50% on controller, and cross it like 51% to left, knob in vdj restarts again on 0% to left.
Which controller and which knob ?
It is AKAI MidiMix... I used first knob on upper left, 0-JOG16 is mark in mappings.
is it because of the controller ? its not supported in vdj ?
