Topic: Denon mk6000mk2 xfader problems
BwhuDControlleristMember since 2008
Hi im using vdj8 with denon mc6000mk2.
I have a problem with the fader when i fade R the fader on screen slides back L and is generally jittery.
I have had the denon 8 months and this problem is a 1st but continues on every use now.
I have warrenty for controller but is this the software/laptop or hardware problem?
Thanks in advance
Tom
geposted Thu 31 Aug 17 @ 2:54 pm
Does it fade smoothly back ? Or it jumps to random positions ?
geposted Thu 31 Aug 17 @ 3:53 pm
Hi PD
It seems to flicker a bit after 15 mins use then start going fully back smoothly.
I have just toggled sandbox settings and that seems to have stopped it but wont know until i use for 45 mins or so.
Thank you for your reply.
Tom
geposted Thu 31 Aug 17 @ 4:00 pm
MellpotPRO InfinityMember since 2013
BwhuD wrote :
Hi PD
Tom
Had this problem on the Mk 1 6000
Crossfader left to right sprayed contact cleaner in slot cured for about 6 weeks but returned again so ordered replacement slider part number 47007JX from CHS but never fitted it i purchased the Mk 2
geposted Thu 31 Aug 17 @ 10:55 pm
Myself and another DJ have had the same thing. The Cross fader is dodgy on all the units and many seem to go like that after even only a few weeks of use. They fixed it because it was under warranty (denon that is)
It can be avoided by just pulling the fader back a little from the final resting point. Stops the jitter but the video from the other track can be seen faintly in the background.
geposted Sat 02 Sep 17 @ 12:12 am
Hi guys
Quick update re this problem that may help anyone.
I noticed this problem was linked to sandbox-when i faded R i noticed the sandbox icon flicking simultaneously
I toggled the s.box settings and noticed the s.box no longer linked to x fader and used for 2 hours with no problems.
Thanks all for replies
geposted Tue 05 Sep 17 @ 3:44 pm
Yep had this on the MK 1 6000 fader would move back on its own or if i touched it cross fader requires clean or new .
geposted Thu 10 Jan 19 @ 12:14 am
