Topic: Setup ASKTHEDJ
It doesnt connect to the server, so that I can make more venuses etc. when I press set up on Ask the DJ button in the browerfield.
Using PC and V.3870
I would like to have a quick response if its somethin wrong with the version of vdj or if it is the server.
geposted Sat 02 Sep 17 @ 8:51 am
Thank you Adion.
But it does not open my webbrowser when I hit the set up in the browser, as it did before ?
It seems to be my computer.
It doesnt connect to internet with some other software aswell.
Is there anyone that has experienced this before and knows why?
Have you scanned for viruses, malware etc?
If you're running anti virus, firewall etc, try turning it off temporarily.
Have you checked your hosts file?
Yeah checked all thing like that, but will check again if Im missing something..
My guess would be something wrong with the default browser configuration.
It was the settings in Firefox (wasnt set as default browser)
Never happened before, thank you for your time Adion.
