Topic: Not Opening on Mac
Tried opening from Spotlight (like I usually do) and the Dock as well as Applications. None work. Program icon pops up on the Dock when clicked like usual. Then a second icon pops up on the Dock and displays a 0-100%. Then nothing.
Restarted the laptop twice. Also re-installed a fresh copy. Nothing helps. Almost positive I was using build 3752. Any advice?
geposted Sun 03 Sep 17 @ 12:26 am
Thank you.
