Topic: APC40 mapping
How do I get rid of the APC40 mapping in VDJ8 PRO and replace it with a completely custom midi mapping of my own?
geposted Wed 06 Sep 17 @ 4:43 am
1) Open Config
2) Go on mappers tab.
3) Select AKAI APC 40
4) Click on an element of the mapper
5) Press backspace (the element should be deleted)
6) Repeat for all the remaining keys
7) Close config
PS:
If you like to speed things up and you are familiar with XML files skip step 6 and follow these steps:
8) Close VirtualDj
9) Go on Documents\VirtualDj\Mappers folder
10) Open the AKAI APC 40 mapper XML file with your favorite XML / text editor
11) Delete all XML nodes leaving nothing but the document base
12) Save the XML file
geposted Wed 06 Sep 17 @ 6:10 am
I built a apc 80.. {40 and 20 apc together }I have had a custom system for virtual dj 7 and 8 .. If you need help feel free to message me .. I will be happy to walk you trough it 100%
geposted Fri 22 Sep 17 @ 4:28 pm
