Topic: Audio missing whilst in BPM editor?
Hi everyone
It seems whilst I'm using the BPM editoe pressing the play button within it doesn't produce any sound nor doe the metronome button.
Anyone else having the same problem or know how to fix it please?
Thanks
geposted Tue 12 Sep 17 @ 10:11 pm
bogartPRO InfinityMember since 2004
Not having issues here
geposted Wed 13 Sep 17 @ 1:11 pm
You might want to check your sound output settings.
Switch the output to "speaker only" and then try to play from the bpm editor. It should warn you about no headphones configured, but since this is a tool better suited for preparation before a gig, it should be all right.
Just remember to switch output back to "speaker and headphones".
Hope this helps :)
geposted Wed 13 Sep 17 @ 2:02 pm
geposted Wed 13 Sep 17 @ 4:57 pm
