Topic: EQ and master FX slot
LDJMaxPRO InfinityMember since 2009
Hello,
Is it possible to have 2 FX slot on master channel so I can leave the EQ10 plugin in one slot and play with other fx in the second? (of course need to modify my skin...)
geposted Wed 13 Sep 17 @ 7:23 am
Yes, you can have multiple master fx slots :)
geposted Wed 13 Sep 17 @ 8:30 am
No need to modify the skin you can call the second slot from a button/s
deck master effect_select 2
deck master effect_active 2
geposted Wed 13 Sep 17 @ 8:45 am
Ok, it works. So now need to modify my skin (I want to have the EQ always showing (vintage?!) ...already done but for now in a separate panel (need to make room on the skin) and map the sliders to some pot
thanks for your help
geposted Thu 14 Sep 17 @ 4:15 am
screenshot
