Hi, just as the title says, I want to run a script after the song is fuly loaded to the deck. Sometimes external hardware is slow with few seconds lag, sometimes fullHD music video takes some time to load fully. So, if I have button that has a script, and if I press it while the deck is still loading, I got unwanted results. I want it to react after the deck is fully loaded. So I tried "deck 1 load ? do_the_thing : nothing" or "deck 1 loaded ? do_the_thing : nothing" or "deck 1 load_pulse? do_the_thing : nothing" - neither works.
Any suggestions?
Any suggestions?
geposted Wed 13 Sep 17 @ 6:37 pm
I don't think there's anything for that. The loaded ? command just checks if there is a track in the deck, not when it's actually fully loaded.
Also bear in mind dependent on some settings not all tracks will actually load completely.
geposted Wed 13 Sep 17 @ 6:46 pm
If it is a manual operation (pressing the button) and not an automated one (execute script automatically after deck fully loaded) you could try that:
loading ? nothing : do_it
I can't find the script in the wiki, but I'm sure I read it somewhere.
geposted Thu 14 Sep 17 @ 7:56 am
What is it that you want to do?
There's not much I can think of that you couldn't do before the song is fully loaded
geposted Thu 14 Sep 17 @ 9:23 am
