Greetings,
Since the last update I got a major issue with my sound. My config (that worked fine before) doesent seem to create sound. I hear sound fine through headphones on the controller and the levels are showing there is sound. Also Master Output Levels are showing on Soft and Hardware. But VDJ waits for sound when you hit record. Silence on the streams
This is my current config:
Aufzeichen = Recording
So I tried to find a way to make it work and I could make the sound working again with this config:
But I dont think its supposed to be like that. I also have weird cackles in my headphones when transiting from one channel to another.
In addition when I start up VDJ somehow the Controller seems to start up in External Mixer Mode even tho it says Internal Mixer Mode in the ASIO Driver.
I noticed that because suddenly the hardware effects work that should only work in External Mixer Mode but I want it Internal.
I have to switch the Device on and off again and click on Internal Mixer Mode in ASIO (even tho it is set to Internal) to make it work properly again. Is there maybe some kind of bug now?
The Version is v8.2 b3870
geposted Thu 14 Sep 17 @ 9:18 pm
its not going to work unless you get it set to internal mixer mode
geposted Thu 14 Sep 17 @ 11:25 pm
please read this http://www.virtualdj.com/manuals/hardware/pioneer/ddjrz/advancedaudio.html
You need a "record" line in the audio Setup. If not working (not receiving audio signal and VDJ waits for sound), most likely you have not declared any of the DDJ-SZ Output (Inputs for VDJ) Channels as REC OUT from the Utilities
geposted Fri 15 Sep 17 @ 4:17 am
Yes it is set to "Internal Mixer Mode" but on VDJ startup it somehow appears to be in External Mode even tho ASIO says it's internal.
Display bug?
Yes I did that as shown in the first picture and it worked since I got the controller 3 month ago. Just after the update it stopped working thus the record out is assigned as channel.
All audio settings are assigned as it is stated in the manual. Mixer is internal. No sound still.
Hence why I ask if there might be a bug?
geposted Fri 15 Sep 17 @ 5:09 am
Reinstalling VDJ and DDJ RZ Asio Drivers solved the issues.
Still odd hmmm.
Still odd hmmm.
geposted Fri 15 Sep 17 @ 2:42 pm
