Topic: Eq and gain buttons
djsxPRO InfinityMember since 2006
Good morning. Suddenly the eq and gain buttons do not work with the mouse in the skin with 2 decks. I don't have problem with other skins. Thank you.
geposted Fri 15 Sep 17 @ 5:48 am
Which skin? The {default}?
geposted Fri 15 Sep 17 @ 7:05 am
yes the default don't work with double click from the mouse.
geposted Fri 15 Sep 17 @ 7:42 am
It works ok for me... Double click brings the eq's back to 12 o'clock
geposted Fri 15 Sep 17 @ 8:43 am
but not back or front 12 o'clock
geposted Fri 15 Sep 17 @ 9:54 am
Sorry... I don't understand what you mean...
As I understand it:
If you have changef the EQ on the screen, and then double click it, it jumps back to 12 o'clock (center)
That's how it works for me
geposted Fri 15 Sep 17 @ 10:08 am
The return works. I can't to move + or - with double click.
geposted Fri 15 Sep 17 @ 10:34 am
when I put the cursor on the circle,
geposted Fri 15 Sep 17 @ 10:36 am
I believe that is not how it is supposed to work.
double click resets the EQ to 12 o'clock.
single click and drag the EQ will change the value.
geposted Fri 15 Sep 17 @ 11:00 am
Before last update I can change the value with double click without drag. I can do this with 4 or 6 decks and welcome skin. Thank You.
geposted Fri 15 Sep 17 @ 2:45 pm
I'm afraid this is not the case
I've now tested several old version, and double click always bring you back to 12 o'clock
You can single click the rim of the eq's to set them to a specific spot. This still works in the latest public version (b3870) and the latest early release (3896)
geposted Fri 15 Sep 17 @ 3:20 pm
Since 3889 this functionality was indeed removed from the default 2-deck skin since the area to click was quite small and the risk of accidentally clicking there was considered larger than it being actually useful.
If you do want this functionality back, you can install 3870 again, and extract the default skin (button at the bottom-right of the options window).
You can then upgrade vdj again, but keep using the extracted skin instead of the built-in default skin.
Older vdj builds can be downloaded here:
http://www.virtualdj.com/download/build.html
geposted Fri 15 Sep 17 @ 3:39 pm
thank you !
geposted Fri 15 Sep 17 @ 4:23 pm
djsx wrote :
thank you !
Oh, you were right.
I guess my skin was default with a twist, so that's why I didn't see any change, and it continued working for me
I'm sorry
geposted Fri 15 Sep 17 @ 4:42 pm
