I use controller traktor s2 mk2 with virtual dj 8.2 and i have problem
If i change the pitch from controller at software is working upside down "reverse"
and if press cue button they dont return at cue point..
Thanks
Virtual dj8.2 pro "buy"
win7
Thanks
win7
geposted Wed 20 Sep 17 @ 10:52 am
I have replied to you via PM.
For others to see:
Please (as a temporary fix) change the mapping of your pitch slider to:
param_invert & pitch
For the cue button please check the cue button behavior on deck options (the white dot next to transport buttons on VirtualDj default skin)
Finally, please keep contact with me so that we can investigate why pitch is reversed on your controller.
Thank you!
For others to see:
Thank you!
geposted Wed 20 Sep 17 @ 12:14 pm
Hello how do I leave the pitch normal and not inverted I installed a controller traktor s2 mk2 and the pitch was reversed automatically, but I want it to become standard someone
Could you explain me how to solve this problem?
geposted Thu 04 Oct 18 @ 3:34 pm
