Topic: saving a playlist problem
Hi all,
I'm currently running build 3870 on 2 different laptops and my desktop(all using win 10).
for some reason I can't seem to save an Automix playlist as a seperate list under Playlists if I load a list from a virtual folder using right click...load in automix... it doesn't seem to want to save it as a playlist in the Lists & Advice folder???
was this always so, or have I missed a new setting somewhere?
Thanks in advance
ray
geposted Thu 21 Sep 17 @ 2:19 pm
If you hit the little gear in the far right corner, it will bring up a window, with an option to save, at the bottom.
geposted Fri 22 Sep 17 @ 1:14 am
@ amahm
thanks for the suggestion, but I knew that already ;-)
I think I found the solution, I just needed to recurse the playlists folder.
solved
geposted Fri 22 Sep 17 @ 10:48 am
