My layout keeps changing overnight and I have to reset back to factory settings. Maybe I'm doing something wrong. Please advise. Top one is the one I want and bottom one is what it changes to.
geposted Fri 22 Sep 17 @ 12:07 am
check
geposted Fri 22 Sep 17 @ 2:07 am
Thanks. I swore I looked at that but that is change that's happening.
geposted Fri 22 Sep 17 @ 10:19 am
Options > touchScreenMode = No
geposted Fri 22 Sep 17 @ 10:22 am
Do you have a laptop from which the keyboard can be removed? (or you otherwise put windows into Tablet mode?)
When you switch between tablet mode and regular mode in windows, the skin will also switch.
geposted Fri 22 Sep 17 @ 10:43 am
No, the keyboard doesn't detach. I would be working on stuff at night and leave the computer on and look in the morning and it has changed. Maybe my wife is going through my computer at night. I think the information that you all have provided will resolve my situation. Thanks again.
geposted Sat 23 Sep 17 @ 1:24 pm
