Hi guys
is there a way to add "tags" to a file using a custom button????
I can already color a file with a custom button, which I use for different moods.
Butttttt........
Butttttt........
geposted Fri 22 Sep 17 @ 11:08 pm
You can add some info with custom buttons, yes.
Could you explain better what ou need ?
An example of adding tag data on the file selected on the browser is this:
browsed_song 'grouping' 'SummerList'
geposted Fri 22 Sep 17 @ 11:56 pm
awesome does this work with all the other tag fields vdj supports?
geposted Sat 23 Sep 17 @ 1:40 am
AWESOME!!!!!!!
that's all I need. Thnx
geposted Sat 23 Sep 17 @ 10:40 am
Yes...
geposted Sun 24 Sep 17 @ 10:15 pm
