I would like to batch delete all the cue points in my music database. Is there a simple way of doing this
geposted Fri 29 Sep 17 @ 4:39 am
There are probably multiple ways
If you don't have anything you want to keep in your database, so you just want to start over with tracks, BPMs, Keys and so on, you can simply delete the \documents\virtualdj\database.xml file, start VDJ, add your music files again and analyze them again
Another option if you know how to process and auto edit XML files is to simply remove all the cue point lines in the database.xml file. You should probably back up the file first in case something goes wrong
geposted Fri 29 Sep 17 @ 5:41 am
thankyou very much for that information
geposted Thu 05 Oct 17 @ 2:43 am
