I've tried resetting virtual DJ already still doesn't work I have to manually go in and press the button on the effect area and I can't even click it on the pm fx or my party mix
is there any fix?
is there any fix?
geposted Fri 29 Sep 17 @ 10:18 pm
Try to delete the native_Beat Grid.ini file you will find in Documents/VirtualDJ/Plugins folder and re-open VirtualDJ
geposted Fri 29 Sep 17 @ 10:50 pm
Tried didn't work any other suggestions?
geposted Sun 01 Oct 17 @ 12:09 am
Are there any other "BeatGrid" (dll) files in the /Documents/VirtualDJ/Plugins/SoundEffects folder ? If so, please delete those as well.
If that doesnt work, try to do a fresh installation of VirtualDJ
http://www.virtualdj.com/wiki/How%20do%20I%20perform%20a%20clean%20installation%20of%20the%20software.html
Use this link to download the installer http://www.virtualdj.com/le/ (not from any other unofficial sources)
geposted Mon 02 Oct 17 @ 6:33 am
