Forum: VirtualDJ 8.1 Technical Support
Topic: Beatgird button won't work
Sunk3nHome userMember since 2017
I've tried resetting virtual DJ already still doesn't work I have to manually go in and press the button on the effect area and I can't even click it on the pm fx or my party mix
is there any fix?
geposted Fri 29 Sep 17 @ 10:18 pm
Try to delete the native_Beat Grid.ini file you will find in Documents/VirtualDJ/Plugins folder and re-open VirtualDJ
geposted Fri 29 Sep 17 @ 10:50 pm
Tried didn't work any other suggestions?
geposted Sun 01 Oct 17 @ 12:09 am
geposted Mon 02 Oct 17 @ 6:33 am
