Hello
I just purchased a Denon DN MC4000 it came with this horrible software which I can't stand to run....I love my VDJ software and how user friendly it is...the setup went completely smooth...as always it does. Though so far I have encountered on issue I only have access to 1 FX Slot which I would like to setup 3 slots which controller comes with...Is there anyway on how to configure this problem.
Any help would be greatly appreciated
geposted Sat 30 Sep 17 @ 1:21 am
Read the VDJ setup guide https://www.virtualdj.com/manuals/hardware/denon/mc4000/index.html
It tells you how to switch between single and multi FX modes.
geposted Sat 30 Sep 17 @ 8:01 am
Thank you groovindj,
I have read instructions...i am still unable to turn on slot 2 & 3 in multi? All i am able to do is go through each one and select and use knob also above...but actual fx slot 2 & 3 will not turn on? Is it something to do with settings?
geposted Sat 30 Sep 17 @ 11:01 am
Press Shift and Tap button together, the Tap button will turn blue. Now try the effect.
geposted Sat 30 Sep 17 @ 2:08 pm
