Im currently using my turntables with a hercules rmx2 i have a delay in pitch respond , and the calibration doesnt seems right
trayed diferent needles same thing.
geposted Thu 05 Oct 17 @ 3:52 am
Are you on phono or line for the input?
geposted Thu 05 Oct 17 @ 12:13 pm
Phono definitaly phono :)
geposted Fri 06 Oct 17 @ 4:17 am
The calibration is not too bad, at 100%
But is it only cosmetical? the pitch slider is picking up changed pitch in skin cosmetically delayed (so that it doesn't wobble around when you bend/scratch etc).
If its only cosmetic, in other words, only in the skin, then you can change the setting in VDJ options for "timecodePitchSliderIgnoreBend" to "no".
This will make the pitch slider more instant in skin (only costmetic),. but will make it more sensitive to pitchbend, scratch etc.
And it its only cosmetical in the skin, its by design a little delayed to not pick up pitch bend and scratches (that does alter the speed/pitch of the song temporarily).
geposted Mon 30 Oct 17 @ 10:55 pm
goona ask again , because is been a while and still have the bery same problem, when i move the pitch on my turntables it takes like 3 seconds for the software to respond
Hercules RMX2
Traktor TCV
Pc core i5
16 ram
2G video
Hercules RMX2
Traktor TCV
Pc core i5
16 ram
2G video
geposted Tue 03 Apr 18 @ 7:42 am
Hello,
Take a look at a thread I am in, this may help but also brings on other problems.
http://www.virtualdj.com/forums/220829/VirtualDJ_Technical_Support/Timecode_Pitch_Response__vdj8.html
geposted Mon 01 Oct 18 @ 8:45 pm
Also how about the "ControllerTakeoverModePitch" setting? could this help?
geposted Tue 02 Oct 18 @ 2:57 pm
