Topic: DDJ-SR Problem
Hi,
I'm having an issue with tracks not playing on VDJ 8.2 (Mac version). The tracks will load the faders and tempo slider work but when i hit the play button the waveform "shakes" and will not play, also the cue button does not seem to do anything. I've updated the firmware and driver for the DDJ-SR, tried it without the mapping, tried it with the mapping. Any suggestions would be great!
Thank you
geposted Fri 06 Oct 17 @ 6:19 am
Sounds like the soundcard is not initialized properly.
Does your OS see and recognize the soundcard?
I have the same issues. I upgrade the firmware and drivers, but it didn't work. I will try to erase my database and do a fresh start. I will do this in some other time.
Go into your settings and make sure your soundcard is selected and channels 1&2 are on master
It's not a database issue.
It's an issue regarding VDJ talking to your soundcard - and that it for some reason currently can't
The database.xml has nothing to do with that
it's works for me with some issues.
