Topic: CDJ2000NXS2 HOTCUE
First:When CDJ-2000NXS2 connects to VDJ8.HOTCUE is position nsanity.
Second:CDJ-2000NXS2 HOTCUE can't change color,I want the color of the HOTCUE to follow the HOTCUE color of the skin.
I'm a Chinese!!! I wish someone could read it!!!!!
geposted Mon 09 Oct 17 @ 1:33 am
Dont understand your first issue. Could you please explain further and provide screenshots ?
For the 2nd issue, make sure the setting nonColoredPOI setting is set to "Per-Cue" value.
If you want to define a different color (and want your HOTUE buttons of your controller to follow,), you need to change those from the POI Editor and not from the Pad Editor. https://www.virtualdj.com/manuals/virtualdj8/editors/poieditor.html
geposted Mon 09 Oct 17 @ 10:12 am
geposted Mon 09 Oct 17 @ 5:35 pm
I'm a chinese .so Engilsh not good.I speak chinese!!!!
HOTCUE的实际位置与CDJ-2000NXS2的HOTCUE位置不是对应的,举个例子:VDJ上只标记出HOTCUE3 但是在CDJ2000NXS2的HOTCUE上显示的位置是HOTCUE1,但是按CDJ2000NXS2的HOTCUE1按钮,映射到软件上的却是HOTCUE3。就是这个意思!!! 翻译一下!谢谢 !!
geposted Wed 15 Nov 17 @ 3:39 pm
when vdj link CDJ2000NXS2 hotcue colour cannot be set!!!!!
geposted Tue 25 Jun 19 @ 11:50 pm
