Topic: routing question
LeharaPRO InfinityMember since 2017
I have 2 EKS XP-5 controllers and an external mixer. how do I rout the cards sound?? I am not getting a signal to the mixer, but both midi channels are working in the GUI. Thanks.
geposted Tue 10 Oct 17 @ 3:16 pm
in the Audio Setup of VirtualDJ settings, do you get 2 entries of XP5 or just one ?
If you get 2, then try something like ..
deck 1 ... WDM/Speakers XP5-1st entry .. Chans 1,2
deck 2 ... WDM/Speakers XP5-2nd entry .. Chans 1,2
geposted Tue 10 Oct 17 @ 5:36 pm
I will be testing this out tonight....thank you for the continued support.
geposted Thu 12 Oct 17 @ 2:04 pm
no, all I get is EKS Wasapi or Otus ASIO4ALL, and a slew of others, but not WDM/speakers.
The controllers are responding in the GUI, but no sound from cards.
I have them in an external mixer mode, but not getting any sound to mixer.
I tried every possible combination and nothing. sux. was trying to set it up for my kids to toy with without spending $$ on a numark party light or something like that.
geposted Mon 23 Oct 17 @ 6:37 pm
