Topic: slideshow vdj 7
im using vdj 8 lads but use my old 7 for doing pictures on screen ect for parties...just got email saying the photis they are scanning are pdf will sbdj slideshow work with theese.
also whats best add on in vdj.8 for slideshow and scroll text cheers
geposted Tue 10 Oct 17 @ 6:49 pm
Don't think the V7 version supports PDF but you can always try when you get the pictures of course.
For V8 see here: https://www.youtube.com/watch?v=yP4igtMJgos or use tellyvisuals/tellymedia
All the info is on the forum if you do a search.
geposted Tue 10 Oct 17 @ 6:56 pm
yeh i did search before but was hoping sbdj made his for vdj8 as im used to them.
geposted Tue 10 Oct 17 @ 7:00 pm
v8 has a default native slideshow built in.
geposted Tue 10 Oct 17 @ 7:04 pm
Nope. As above, V8 has it's own built in slideshow and scroll text.
yeh just watched the video looks fairly simple.
ill get the files and try at home with 8 before gig.
cheers lads
geposted Tue 10 Oct 17 @ 7:08 pm
ok so trying to sort out slideshow act on my Mac.my clip banks that were transferred from windows will not play for slideshow or audio visuals any advice or is it not good on Mac
geposted Wed 11 Oct 17 @ 6:31 pm
ok so meed to mess around rather than jump on here lol.
so you just select folder instead of first pic old way
little bit more playing around should be ok.
geposted Wed 11 Oct 17 @ 7:20 pm
all went smooth lads thank you.
is there a way of speeding up the text as no option on vdj8
geposted Mon 16 Oct 17 @ 7:08 pm
