Hi i just downlod this now, but when i speak
i hear my voice in my headset
how can i fix it?
how can i fix it?
geposted Wed 11 Oct 17 @ 12:43 pm
leilalah wrote :
when i speak i hear my voice
That's normal. It' supposed to be like that, so you can hear what you're saying, and so you can balance the level of the music against your voice.
Assuming you actually do want to speak, that is. If you mean that your computer is picking up room sound from a built in mic, then you need to disable the mic input or turn down its level.
geposted Wed 11 Oct 17 @ 5:09 pm
