Topic: Pioneer DDJ-RZ Color FX Function
Hello everyone,
the mapping for the controller works quite good, there is only one little problem: with VDJ8 i can use the Color FX "Pitch" and "Filter" but "Jet" and "Space" do not work on the normal channels 1-4. But when I use a mic all four Color FX can be used to change the sound of my voice. Is there an opportunity to use all effects also on the channels 1-4.
Thanks
geposted Thu 12 Oct 17 @ 5:30 pm
Color FX on MIC channel are hardware operated, that's why you can use all 4 effects.
However we are happy to announce that an update will come very soon that will allow you to use all 4 color effects on all other channels as well
Thank you!
Did this happen? I used my DDJ-RZ yesterday and found the same issue as the OP - only Pitch and Filter affect the audio.
Yes. The 4 buttons offer Reverb, Flanger, Pitch and Filter as Color Effects.
Perhaps you were using a custom mapping ?
I don't think so but I'll check again.
