Hi all
I've just upgraded to High Sierra and installed an SSD drive.
I am now experiencing an issue which is that when trying to open Virtual DJ 8 (freshly downloaded build 3936.1349), I have to start the app three or four times before it actually opens.
Once it does open it appears to be stable, but I assume there must be some underlying errors which are causing this behaviour.
Has anyone else noticed anything similar?
geposted Fri 13 Oct 17 @ 2:23 pm
So at your first couple of attempts you dont get anything on the dock, nothing happens ?
geposted Fri 13 Oct 17 @ 4:33 pm
Sorry for the really slow reply, I've been super busy recently.
I did some more experimentation and it seems that something in my home folder did not agree with High Sierra - my home folder worked fine on El Capitan, and also on a borrowed MacBook that I used while mine was being repaired, but when I copied it to my new setup with High Sierra, it caused the above issue.
I ended up rebuilding my home folder from scratch and then importing my playlists and history folder by folder. Seems to be fine now.
geposted Tue 17 Oct 17 @ 6:26 am
