I've lost my settings,, I was able to press a loop button and it played the loop from the previous hot cue, but have no idea how I set this up, and can't find details on such a function, any help much appreciated, was a cool function to have
geposted Fri 13 Oct 17 @ 4:45 pm
cue_loop :
Jump to a cue and stay in a loop. Use cue_loop_temporary to select if loop is temporary, or stays until pressed again. Respects smart_cue when jumping to the cue
geposted Fri 13 Oct 17 @ 5:43 pm
Cheers for the reply, doesn't seem to work as a command on script, I think the script was quite long it's something I stumbled on the Internet, but can't find again, but was really useful, ?
geposted Fri 13 Oct 17 @ 8:44 pm
cue_loop should work fine. Did you write it in with the underscore ?
geposted Mon 30 Oct 17 @ 10:42 pm
