Forum: Old versions
Topic: Playing Visuals on mp3s with VDJ8 on a Mac
I have searched for a couple of hours and haven't found too many recent posts about this so here goes...
How the hell do I play some visual on an mp3 on a Mac? Telemedia and Milkdrop are for windows. And Clipbank is a mute issue. Anything for Mac? Is my best bet to go back to VDJ7 Pro?
Thanks in advance.
geposted Fri 13 Oct 17 @ 6:26 pm
What did you use in vdj 7 then?
In 7 I used Clipbank.
Then you can simply use Slideshow in VDJ 8.
Just make sure all the clips you want to use are in one folder, and select that folder in Slideshow.
Then you can setup slideshow to be used as audioOnlyVisualisation.
