Topic: Virtual DJ Remote FX Unit
Hi community Can anyone tell me if there is a skin for VDJ Remote that is just a Effects Unit I use Numark Party Mix+Laptop and Android VDJ Remote App for my effects But I am using the Default Skin with very little control over The FX would it be possible to ake an FX unit only for the remote connection ?
Thanks in advance for any insight, Mix Daddy Dan
geposted Wed 18 Oct 17 @ 10:36 pm
Thank you yes I can and it looks exactly like what I am after
is there a version for Android?
that works on any remote android and IOS
i think it says ipad cause its designed for 10 inch screen.
Ok thank you
