Hello community,
I'm new and wanted to combine my premium spotify with the virtual dj Pro version (I have abo).
My version-number is: 8.2 pc build 3954.1349 VirtualDJ PRO Subscriber
and in the option I have a check mark on yes ate the option: earlyAccessUpdates
now my question: I read on different sites in the internet, that my version can be combined with spotify, so I can use my music from there, if I accept earlyAccessUpdates and have premium of both, VirtualDj and Spotify, but when I go on the folder "online music" there is only the option to login to deezer, I thought there should be the option for downloading an plugin for spotify!? Do you maybe know, what I did the wrong way?
Greetings,
Carsten
Greetings,
Carsten
geposted Fri 20 Oct 17 @ 4:46 pm
You did nothing wrong Spotify decided to block vdj from using the plugin.
Look here https://www.virtualdj.com/forums/217233/General_Discussion/_NOTE__Spotify_integration_in_VirtualDJ_(Update_pr_Sept__2017).html
geposted Fri 20 Oct 17 @ 4:49 pm
Please continue this conversation, at the link provided in above post, thank you.
Locked by AMAHM
Locked by AMAHM
geposted Sat 21 Oct 17 @ 8:23 am
