Could someone check to see if the script:
kill_low_eq
works for them?
I've tried mapping this script to a number of keys on the keyboard and no luck.
Equipment:
VDJ8.2 b3954
Over spece'd MacBook Pro with Retina Display
kill_low_eq
works for them?
Equipment:
VDJ8.2 b3954
geposted Wed 25 Oct 17 @ 3:53 am
It works ok for me using the same version
I did need to change away from using cheap in ear headphones to a set of DJ headphones (the cheap ones didn't include enough bass to tell when I killed it)
I made a small video to show it working
It also shows the bass label changing to red when enabling kill
And I also turn down the bass manually so you can check if it's something else in you audio line that messes with it
EDIT: I'm on Windows though. Don't own a Mac.
I don't know if that can make a difference
geposted Wed 25 Oct 17 @ 6:11 am
kill_low_eq
works for them?
kill_low_eq
works for them?
maybe you type it wrong ?
eq_kill_low
geposted Wed 25 Oct 17 @ 2:58 pm
eq_kill_low
kill_low_eq
works for them?
kill_low_eq
works for them?
eq_kill_low
eq_kill_low
works
geposted Wed 25 Oct 17 @ 3:06 pm
Plus you need to make sure you are in the correct EQ mode. One allows full kill, the other doesn't.
geposted Wed 25 Oct 17 @ 6:20 pm
