Topic: Adding a Jingle To My Pads
Hi everyone I have been looking for a way to add my Jingles to my Pads I have the Manual If someone could point me in the right Direction
I have a few jingle MP3 and would love to add 1 per pad I have 4 pads per Deck
I am using a Numark Party Mix with the Latest version of VDJ. Any help will be greatly received.
geposted Wed 25 Oct 17 @ 4:32 pm
Is a free trial available from virtual dj ?
How long is the trial ?
Thx
geposted Wed 25 Oct 17 @ 4:50 pm
geposted Wed 25 Oct 17 @ 4:56 pm
Read the manual. There's a whole section on the sampler.
geposted Wed 25 Oct 17 @ 6:23 pm
Yes, you need the sampler and sample banks
The general idea is that you add you jingles into the sample banks (under lists & advice in the browser tree), select between you sample banks, which you can also show in the bottom right part of the screen, and then trigger the samples when you want it.
If you have the standard pads on your controller, and select the sampler pad page, you 8 pads will trigger the first 8 samples in the selected sample bank
You can adjust on each sample if it should play continuously, only while pressed, should loop, adjust it's key and/or tempo to the music, and so on i
More info in the manual and also here:
https://www.youtube.com/watch?v=p1ZOW4S2Bqg
https://www.youtube.com/watch?v=78QW28VVGuc
geposted Wed 25 Oct 17 @ 7:14 pm
Many thank for the information
geposted Wed 25 Oct 17 @ 7:46 pm
All Sorted thank you I was not editing the File that was my problem
geposted Wed 25 Oct 17 @ 8:23 pm
