Topic: Video take while to start
Whenever I insert a video into one of the deck, it takes about 5 to 10 second to start. I've updated all of the hardware within the computer. Also, uninstalled and reinstalled VDJ8 and still having the same problem. Can someone please help me.
System
Dell Precision 5520
Win 10 pro 64-bit
Inel i7 2.80
32GB Ram
geposted Fri 27 Oct 17 @ 9:18 pm
do you scan files before you load them? if not that would help.
geposted Fri 27 Oct 17 @ 9:28 pm
Yes... All files, audio and video are analyzed.
geposted Fri 27 Oct 17 @ 10:36 pm
What do you mean exactly by this 5 seconds?
You cannot press play instantly after dropping?
Or it is only the video that starts 5 seconds after you press play?
Is audio starting instantly?
geposted Sat 28 Oct 17 @ 4:04 am
When the video is drop in the deck you can tell that it take a while to process and if you press play too soon, it would freeze for a while but then starts to play. This happen even if I'm already playing an audio then drop a video or if the first track is a video when I start VDJ8. There is no problem after the first video, everything runs smoothly after that. Audio no problem.
geposted Sat 28 Oct 17 @ 11:51 am
