Topic: RECORDING VOLUME IS LOW
I recorded with VDJ but the volume was very low on the CD, what should my settings be on the controller? Please help.
geposted Sat 28 Oct 17 @ 1:45 am
Your master volume also affects the recording volume, so often it's your master volume not being all the way up while recording
My setup for recording is:
- make sure all my tracks are adjusted to 96db (I do this just after I've bought them)
- turning master volume all the way up in VDJ (and handle volume on a mixer, amp or the active speakers)
- always have my deck volume at 100% for the current master track
- record in highest mp3 format (320 kbps)
- setting zeroDb to -3 db to give me mixing headroom
Then my recording is always around 93 db (96 db from the tracks, -3 db from the setting and fine-adjusted by auto gain
I can then of course adjust this all the way up to 96 db on the mixed track if I like, using something like mp3gain
geposted Sat 28 Oct 17 @ 10:53 am
