Topic: Virtual dj goes erratic
2mvp8102PRO SubscriberMember since 2014
I'm using hotcues , all of a sudden it's on another action then my wheel just starts jumping all over ......music crazy jumping ...no control over anything,
geposted Tue 31 Oct 17 @ 1:20 am
geposted Tue 31 Oct 17 @ 2:13 am
Since you are here, what controller, OS, version of VDJ, and any other important information would help.
geposted Tue 31 Oct 17 @ 3:38 am
Numark Mixtrack Quad..
Windows 8
Akai MPD218
I unplugged the Akai and plugged it back in and it was fine ....is it a new cable I need or is it maybe was just loose.
geposted Tue 31 Oct 17 @ 3:38 pm
Well, I think that you should be able to answer that. Why not try a different cable and see. It may be the port on the controller, but I don't think anyone here can actually answer that question either. Do some testing, and get back to us.
geposted Wed 01 Nov 17 @ 7:47 am
2mvp8102, please don't post the same issue in different threads, thank you.
geposted Sat 10 Feb 18 @ 8:56 pm
