im thinking about purchasing Virtual DJ with the audio package to have access to all the music online..anyone using this and is it easy to use? Cheers all!
geposted Tue 31 Oct 17 @ 7:09 pm
Hi, and welcome to site.
VDJ and its audio catalogs are very easy to use.
And you can even try-before-you.buy... :)
Use the online music folder inside VirtualDJ, and you can search and test 30 seconds of each song before you decide ..
Hope that helps :)
Can read a little about the feature here:
https://www.virtualdj.com/manuals/virtualdj8/interface/database/onlinemusic.html
geposted Tue 31 Oct 17 @ 10:37 pm
