Forum: VirtualDJ 8.2 Technical Support
Use this forum to report any bug, questions or comment related to the latest version of VirtualDJ 8.2.
Forum Guidelines
(NOTE: VirtualDJ 8.2 is continuously updated, so many older topic on this forum are most probably already fixed in the current build)
Topic: Live Feedback
Any chance of adding an Option to write the Live Recommended Feedback tracks to txt file. The reason I ask for this is that It recommends only 4 tracks replacing to oldest each time and I miss some of the recommendations and it would be nice to see after I have finished what ones I do not have and go take a listen and see if its something I wish to purchase. Many thanks please keep up the fantastic work really loving VDJ 8.2
geposted Thu 02 Nov 17 @ 7:40 pm
You could check your history list of the night, select all tracks, right-click and select 'Search with GeniusDJ' to get more recommendations based on your playlist.
geposted Fri 03 Nov 17 @ 4:33 am
I looked at that but as the Thread title explains I want the Live feedback logged to file not the tracks I already own and play. thanks for your input just not what I am looking for
geposted Fri 10 Nov 17 @ 4:43 pm
Do you realise that VDJ can be set to save any unsuccessful searches to a text file?
I know it's not ideal, but any suggestions that come up - if you enter them into the search box and get no results, that search can/will be saved.
geposted Fri 10 Nov 17 @ 6:21 pm
I did not know that and thank you I always search so they are here somewhere that is perfect thanks again
geposted Tue 28 Nov 17 @ 10:55 pm
