Controller: Korg Kaoss DJ
OS: Win10
VDJ: 8.2 b3954
Steps:
- load tracks, go to "scratch" tab, select beatlock on both sides
- play both tracks, several times click play/pause and sync buttons on the controller
Result: after clicking Sync button VDJ hangs, music stops playing, UI unresponsive, system process hangs.
Notes:
- could not reproduce using play/sync buttons in the the app UI, i.e. only physical "sync" button on the controller caused the issue.
OS: Win10
VDJ: 8.2 b3954
Steps:
Notes:
geposted Fri 03 Nov 17 @ 9:52 pm
Can you reproduce the same issue if you use the computer's built-in sound card and not the Korg in Audio Setup of VirtualDJ ?
What are the specifications (CPU, RAM, Video card) of your computer ?
geposted Sat 04 Nov 17 @ 12:05 am
VDJ got updated to b3967, the issue still appears.
Yes, can still be reproduced when internal sound card is selected in audio settings.
core i5, 4GB RAM, intel hd graphics 520
geposted Tue 07 Nov 17 @ 10:11 pm
I noticed the exact same issue, Im running VDJ8 Latest Ver, Pioneer ddj sb2 & I5 16gb ram 512gb ssd w10. stable if you dont use beatlock any fix for this ?
geposted Sat 30 Dec 17 @ 8:10 pm
beat lock and sync button are not the same thing sorry
i use pitch_lock all the time with no issue some reason that will not work for you?
what are you using to active beatlock? could this be the sync button?
if so you beatgrids are probably off and need adjustments.
geposted Sat 30 Dec 17 @ 9:17 pm
