Topic: Saved Loops navigation interface
I'm using a DDJ-SB2, I've remapped almost all my buttons. I would like to utilize saved loops and/or remix points instead of standard hot cues/auto loops.
To achieve this, I would need a way to quickly cycle through save loops. As there can be up to 99 saved loops, an interface that allows me to quickly navigate (preferably using the controller) the loops would be ideal (I can look at the laptop, I just don't wish to have to touch it to navigate the loops).
Is there anything out there like that? Like an interface that I can launch from pressing a button that gives loop names and a means to navigate it using virtual dj commands?
geposted Sun 05 Nov 17 @ 2:39 pm
If I understand you correctly:
I guess you could use the Pad Pages and list 8 (or 16 with shift) at the time
For that you'd make a few custom pad pages for saved loops >8 based on the current saved loop pad page, and map a couple of keys to jump between the them
But I don't see in which scenario you'd need 99 saved loops in 1 track
Seems like you are maybe trying to do something that would work better using looped samples
geposted Sun 05 Nov 17 @ 5:52 pm
