Running 8.2 Build 3954 and i notice in settings i have "auto load" on the headphone set to "always" and when i load a song on say deck a the headphone cue does not switch over. I try that with setting to "yes" on auto headphone load and same problem. It will not auto switch to the song that is loaded in deck a or deck b.
geposted Tue 07 Nov 17 @ 6:54 pm
If your audio configuration is external mixer this probably won't work no matter how it's set.
geposted Tue 07 Nov 17 @ 7:03 pm
Its not. Its set headphone + speaker
geposted Tue 07 Nov 17 @ 9:22 pm
The automation will stop if the selected Deck (A, B or 1,2,3,4 in case you use the 4 decks skin) doesnt match the status of the PFL buttons. E.g. while deck A is selected and you manually press the PFL on the right deck.
If you want the automation back, you need to match the selected deck and the PFL status (e.g. when right deck is selected, PFL on left deck should be off and PFL on right deck should be on).
Tip. If you dont want the PFL to change when you touch the Jogwheels, and only want to change automatically depending on the deck you load, then maybe set this option to "on Load" instead of "always"
geposted Wed 08 Nov 17 @ 12:48 am
Hi There, running v8.4 b5402 the auto headphone is not working anymore. earlier it used to work perfectly but now after update i have to press PFL manually to do so.
i have tried all option (On Load, Always) but no luck. i'm using PIONEER DDJ SX2. it was working earlier with same controller but now it's not. i don't know weather it's bug or what. can someone help please? i have a habit of auto headphone but when it's not working now i get confused because of that. any help would be highly appreciated .
geposted Sun 17 Nov 19 @ 12:54 pm
Try pflOnSelect to Yes In Settings.
geposted Mon 18 Nov 19 @ 1:54 am
What controller are u using?
geposted Sat 25 Jan 25 @ 10:30 pm
You're replying to a post made seven years ago.
geposted Sun 26 Jan 25 @ 10:21 am
... and i hv my reasons for asking. U can bypass it.
geposted Mon 27 Jan 25 @ 9:42 am
The solution was provided in 2017.
geposted Mon 27 Jan 25 @ 9:56 am
